Gsm-Forum.:Geo-Gsm:. GSM CDMA FORUM
Proudly Hosted by: FMEOS
E-Commerce Solutions Hosting
Web Hosting Pakistan - Cheap Domain Registration Pakistan
Go Back   Gsm-Forum.:Geo-Gsm:. GSM CDMA FORUM > Other Gsm / Mobile Phones Related Forums > Universal Software
Notices
Universal Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers...
Thead: Flash,Update,Unlock,Downgrade Your Nokia(BB5) without BOX!!!
Reply
Thread Tools Display Modes
Old 03-05-2009, 09:50 PM   #1
wawan_berau
Junior Member
wawan_berau is on a distinguished road
Thumbs up Flash,Update,Unlock,Downgrade Your Nokia(BB5) without BOX!!!
- Just download the JAF sw and its Emulator and run emulator, if you wanna flash or reset security code run JAF MAIN, if Unlock then run JAF UNLOCKER.
COMPLETLY TESTED AND WORKING LIKE CHARM
How to work with flasher ?
1.mark "manual flash" then press on MCU and PPM and CNT one by one and select the required flash image files.
( MCU: main image file, larger than other PPM: it contain language pakages CNT: it contains multimedia files )
2.connect completly turned ON phone to USB and select PC SUITE mode from the pop-up menu, drivers should be installed.
3.for normal flashing only mark "CRT 308" , "Factory Settings" , "Normal Mode" and press flash
4.for flash dead phones only mark "Dead USB" , "Normal Mode" , "Factory Settings"and press flash then do simple 1 power on phone.
5.for downgrade phone's firmware only mark "Downgrade", "CRT 308", "Normal Mode", "Factory Settings" and press flash (phone should be ON for downgrade)
- here some screen shot and status logs of its work :
Status LOG of Dead USB Flashing :
Code:
JAF version 1.98.62
Detected PKEY: 9000A86B
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 6.86.15.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.ppm_a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.image_a
Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Icelandic
Detected P-KEY: 9000A86B
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
	Elf2flash 02.33.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting...............................................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 1424, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.mcusw...
Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00020000 - 0007FFFF ... Erase result: 0000
Erasing cmt zone 00080000 - 000DFFFF ... Erase result: 0000
Erasing cmt zone 00100000 - 001FFFFF ... Erase result: 0000
Erasing cmt zone 00200000 - 0031FFFF ... Erase result: 0000
Erasing cmt zone 00320000 - 0105FFFF ... Erase result: 0000
Erasing cmt zone 01060000 - 01067FFF ... Erase result: 0000
Erasing cmt zone 01068000 - 0107FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.ppm_a...
Erasing cmt zone 01080000 - 015FFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.image_a...
Erasing cmt zone 01600000 - 01FDFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Sending CMT HASH for PMM_CONF
Sending CMT HASH for SBIF_CONF
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V 06.60
21-05-08
RM-217
(c) Nokia.
APESW: (null)
VariantSW: (null)
Prodcode: 0537631
Done!
Status LOG of downgrade flashing :
Code:
JAF version 1.98.62
Detected PKEY: 90009A4F
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.ppm_a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.image_a
Backing up CRT...
Detected P-KEY: 90009A4F
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\359538017854627_CRT_backup_2144191.pm
Done!
Backup CRT OK!
Preparing for downgrade...
Phone ready for downgrade!
Reading SW version...06.60
Reading battery value...3999 mV
Init usb flashing...
Reading flashid... 128k flash detected.
CMT: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 2
Scanning selected flash files...
Found CMT ULO server in flash file...
ADL->Loader: Update Application Loader -> Single Chip
Loader len: 240192, CHK: 0x26DB
ADL -> Sending loader...
Status byte: 0400
Result: 0000
CMT blocks: 1408, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.mcusw...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.ppm_a...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__05.50.image_a...
Send CMT CFG...
Writing cmt...
Writing 128k page converted flash...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V 05.50
14-08-07
RM-217
(c) Nokia.
APESW: (null)
VariantSW: (null)
Prodcode: 0537631
Done!
DOWNLOAD LINKS :
JAF 1.98.62 :
Code:
[Only registered and activated users can see links. ]
JAF 1.98.62 Emulator :
Code:
Nokia Flashing Cable Driver :
Code:
Nokia Connectivity Cable Driver :
Code:
wawan_berau is offline   Reply With Quote
The Following 5 Users Say Thank You to wawan_berau For This Useful Post:
2unit (07-04-2009), bishnu (04-27-2009), BOUHRIZI (05-03-2009), fazi_58 (03-29-2009), wayjar (05-01-2009)
Sponsored Links
Old 03-09-2009, 11:45 AM   #2
Tania
Junior Member
Tania is an unknown quantity at this point
Need to say thank you for a rapidshare links
Hello,
Many Thanks for this one
Thanks
Tania is offline   Reply With Quote
Sponsored links
Reply
Bookmarks
Tags
downgrade, flash, nokiabb5, unlock, update
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsored links
linkbee click me rapalbums.net Aus GSM Forums Inovasi-Mobiles.com digg Flash Files best Games flach tagenie.com Pcw-Home visit Gsm Forum Geo-Gsm GSM CHAT ONLINE Make Money For Sharing Links shrak-mobile
Useful links:
AceInn - World Class Hotels :: eCommunity - online Community : Great Hotels America :: Lance - Freelance :: London Ways - London Travels :: PakBird :: Computer Information :: World Book :: Virus Information :: XE - Universal Currency Converter :: :: Latest mobile phone prices in Pakistan ::
Powered by vbulletin
Proudly Hosted by: FMEOS.Pk
Designs by hotlovercool4 (ShafeeQ Ahmad)
Ad Management by RedTyger
3 4 5 6 7 8 9 11 12 13 14 15 17 18 19 20 21 22 23 24 25 26 27 28 29 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 121 122 123 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 182 183 184 185 186 187 188 189 190 194 195 197 198 199 200 201 202 204 205 206 207 208 209 210 211 212 213 214 217 218 219 220 221 222 224 225 227 228 229 230 231 234 235 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351
